Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > 80/20, TSLOTS and other Aluminum Framing Systems
80/20, TSLOTS and other Aluminum Framing Systems Discuss Modular T-Slotted Aluminum Framing Systems here!
  #13   Ban this user!
Old 01-08-2008, 03:46 PM
L2A3 is on a distinguished road
Jason,
the panels are 100% made of plastic, probably pvc. If you go to a building center, look in the 4x8 paneling area. This stuff was called Dura thermal lite or something like that. It has cellular ribbing cavities inside it for strength, basically the same design as heavy duty cardboard only all plastic. I think any paper product would eventually fail. Not sure about wood and paint, I guess it depends on how you do it.
  #14   Ban this user!
Old 01-08-2008, 06:50 PM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
Very true, I knew it wasn't foam board it would make no sense. Ok, I'll need too check lowes or Home Depot.
-Speed
  #15   Ban this user!
Old 03-26-2008, 02:17 PM
midmod is on a distinguished road
I think they call that material choroplast at a sign shop.
  #16   Ban this user!
Old 03-27-2008, 10:00 AM
kwms1956 is on a distinguished road
There's a good selection of TSlots remnants on the Automation Overstock website (www.automation-overstock.com). If you can't find the extrusions you need on EBay, they might have what you need.
  #17   Ban this user!
Old 01-12-2009, 06:07 PM
napalm03 is on a distinguished road
Nice Enclosure! Good ideas on coolant recovery also.
  #18   Ban this user!
Old 01-13-2009, 11:06 AM
rowbare is on a distinguished road
The fluted plastic is called Coroplast ( http://www.coroplast.com/ ) and a very small select can be found at Home Depot though you can probably buy it cheaper from a sign shop or plastics supplier. Another option is Expanded PVC.
  #19   Ban this user!
Old 04-21-2009, 12:32 AM
emills is on a distinguished road
Great enclosure. I love it!! I want one.
  #20   Ban this user!
Old 11-21-2010, 08:45 AM
Fastest1 is on a distinguished road
Beautiful enclosure. I do wonder about your straining of the coolant though. Why not have a settling tank first instead of all the screens? Of course you will still need some screening but if using an overflow system it would catch most. Also how are you tilting the floor? I see plywood under the whole enclosure but it all looks pretty level. I run a large flat pan under my mill at the moment and quite a bit of coolant is slow to drain. How about a video on youtube of the whole system in action?
80/20 TAIG CNC Mill Enclosure tikka308 Taig Mills & Lathes 17 12-06-2007 04:43 AM
Want to make an Enclosure around my Taig Mill! SpeedsCustom Taig Mills & Lathes 53 10-30-2007 10:09 AM
Taig Enclosure Overkill pdxalz Taig Mills & Lathes 8 09-19-2007 05:38 AM
Taig enclosure finished! (Update need help!) Astroguy Taig Mills & Lathes 6 06-20-2007 07:37 PM
My TAIG enclosure is here! Smertrios Taig Mills & Lathes 15 04-24-2006 05:31 PM
