| 80/20, TSLOTS and other Aluminum Framing Systems Discuss Modular T-Slotted Aluminum Framing Systems here! |
| Fabricating 80/20 What is the best way to fabricate these parts? i.e. cutting, etc. I have used aluminum in the past with a chop saw blade for my miter saw. It does a better job on steel. I think it heats the aluminum too much because I get allot of burs that require grinding and filing. I'm looking to make a clean cut. I heard you can cut them with standard table saw/ miter saw blades. Just looking for the collective thought on this. |
| Yeah, an abrasive "chop-saw" blade is no good for this...you need a carbide tipped blade...preferably one designed specifically for cutting aluminum extrusions, as the pitch, set and rake are optimized for the job. (here come the leghumpers... )A standard miter saw will work reasonably well for low volume work, but if you need more capacity a purpose built cut-off saw will serve you better. A decent middle of the road solution is the DeWalt DW872... :twocents: Ymmv... |
| Perhaps ill look for a new blade. I have never worked with 80/20 before, but for cutting small parts like angle, u/t channel, the regular carbide blade felt like it was going to bind unless I went real slow. |
| A cutting wax stick can help too, but it won't completely make up for the wrong blade... |
| I am finishing an enclosure made with QuickFrame components (by 80/20). The framing cut easily and clean using a horizontal band saw. To trim & remove channel flanges from the 1"x1: tubes, I ran them in a vertical band saw set with a run-of-the-mill wood blade. Both worked excellent. Hope to post pictures soon. |
| Miter Saw and a good carbide blade (the more teeth the better) and add a shot of WD-40 to the blade after every few cuts. |
| An 80-tooth carbide-tipped blade with zero tooth offset, or "pitch", works like magic. Normal carbide blades for wood and the like have a staggered offset to the teeth which will cause problems cutting Aluminum. Proper commercial-duty aluminum cutting blades cost a couple of hundred bucks, but Home Despot has a Diablo blade for about $55 bucks that works just as well and will still last far longer than we will ever need it to. I have a 10" chop saw outfitted with one just for my 80/20 cutting. |
There is a different grade of carbide, and a different grind on non-ferrous metal cutting blades vs wood blades.
__________________ David |
| Fabricating Natural Stone | thoth | Glass, Plastic and Stone | 11 | 06-01-2007 10:14 PM |
