Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > 80/20, TSLOTS and other Aluminum Framing Systems
80/20, TSLOTS and other Aluminum Framing Systems Discuss Modular T-Slotted Aluminum Framing Systems here!
  #13   Ban this user!
Old 01-23-2011, 10:12 PM
mechtech10 is on a distinguished road
If what you are referring to is the aluminum c-block with plastic inserts - well, these are not intended for accuracy, and under load probably a little too much friction. If you can get Delrin slides, you'll have lower friction, but the fit is probably no better.
Brad
