Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > 80/20, TSLOTS and other Aluminum Framing Systems
80/20, TSLOTS and other Aluminum Framing Systems Discuss Modular T-Slotted Aluminum Framing Systems here!
Old 12-21-2011, 11:42 AM
EKFER's Avatar
EKFER is on a distinguished road
What extrusion should I use to build a cnc table?
I',m considering to setup a table for my cnc machine using 8020 inc. t-slot extrusions (15 series). Is that strong enough for holding and cutting 1/2" aluminum? I'll appreciate your response. Thank you
Old 12-21-2011, 01:49 PM
bobsch's Avatar
bobsch is on a distinguished road
What size table are you thinking about?
Bob
"Bad decisions make good stories."
Old 12-21-2011, 02:12 PM
keebler303 is on a distinguished road
I'm gonna go with 3060 extrusion...
Old 12-21-2011, 07:24 PM
EKFER's Avatar
Thank you for your responses. The size of the table will be 15" by 36.250.
Old 12-27-2011, 11:38 AM
MikeyC38 is on a distinguished road
Hi Ekfer,
I'am at the stage where I have my ballscrews, rails and bearings and doing my design. My MC will have 1100mm x 750mm x 300mm ball screws to cut wood and
aluminium. I think you need bigger sections because this gives greater stiffness and better accuracy. I am using 40x80 (heavy) sections (4 kg/m density) and 120x40 (heavy) section for the y axis gantry section to support the Z axis. I will be using 15mm aluminium toolplate for the gantry sides and end plates. With 3.1nm steppers (427oz) this sould be plenty to mill aluminium to a good accuracy (0.01mm). On the UK mycnc forum there are some useful design spreadsheets to work out the deflection for a given load and box section size.
Hope this heps
Mike
Old 12-27-2011, 07:26 PM
EKFER's Avatar
The main consideration I have is to maintain a low profile while, at the same time be able to clamp on both sides. How about a 1/2 x 15" x 36.250" anodized aluminum plate with threaded holes? Who makes them?
Old 12-27-2011, 07:31 PM
EKFER's Avatar
Friends, I read from Bear5k today that Misumi has a heavier extrusion at a better price. I'll look into it. Again, thank you all for your assistance and recomendations.
Old 12-27-2011, 08:18 PM
EKFER's Avatar
Techno Inc. has exactly what I'm looking for (HEAVY DUTY EXTRUSION TABLE PLATE 20375). However, at US $341.00 it is beyond my purchase ability. I'll keep looking. Or, if you find an alternative , please let me know. Thank you
Old 05-16-2012, 08:51 AM
TNUTZ's Avatar
TNUTZ is on a distinguished road
Faztek
Have you given Faztek.net or Faztek.ca a try? They seem to be less "busy" than 80/20, and will spend the time to make sure that you get what you need.
Old 05-16-2012, 10:44 AM
Do you deal with 80/20 directly or through a distributor? I have had excellent service through my local distributor, granted my projects are normally $2-5k so I'm sure that helps.
Matt
  #11   Ban this user!
Old 05-16-2012, 10:55 AM
TNUTZ's Avatar
Matt
As far as I know, you cannot buy direct from 80/20, so you are stuck with the local distributor. For many small "dollar" jobs, you don't always get the service.
Aluminum T-Slot Build Using Misumi Extrusion Bear5k T-Slot CNC building 54 05-05-2012 01:38 PM
Build Thread- Aluminium Extrusion CNC Router Build joshendy CNC Wood Router Project Log 77 04-18-2012 08:17 PM
New Machine Build- Aluminun Extrusion Custom Build AZicuRN CNC Wood Router Project Log 8 07-28-2010 11:56 PM
New build! Gantry style based on Ahren's parts and 80/20 extrusion groomden DIY-CNC Router Table Machines 10 04-02-2009 10:40 PM
