Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > 80/20, TSLOTS and other Aluminum Framing Systems
80/20, TSLOTS and other Aluminum Framing Systems Discuss Modular T-Slotted Aluminum Framing Systems here!
Old 09-06-2010, 07:24 AM
cslarson is on a distinguished road
Modified CRP100-00 with center rack and pinion x-axis
Hello all,
The following is a cad mock up of a modified crp100-00 design from cncrouterparts.com with their rack and pinion system mounted going down the middle of the frame. The gray framing is all based on 15 series 8020 aluminum. The R&P systems I've seen so far utilize two sets for the x-axis and I'm wondering if something like the following might work to reduce this to one. I doubt it would save much money, but I wanted to share it anyway.
Everything else would be the same as the crp100-00 design so I've only done a quick cad model of what the elongated (60inch) x-axis might look like with the r&p going up the middle. There would be 4 "extended linear carriages" for the x-axis. I wondered if this would have some stiffening benefit.
I'm interested in a longer version because I would like to make molds for wind turbine blades.
I'd be interested in feedback based on the main concept. I realize the cad model is lacking in detail.
Last edited by cslarson; 09-06-2010 at 07:30 AM. Reason: my hand slipped and i pressed submit by accident!
Old 09-06-2010, 07:34 AM
picassa not so good?
ok maybe picassa doesn't work so well to post pictures. here's another attempt.
Tags
8020, cncrouterparts, rack and pinion
rack and rack & pinion with off the self planetary gearbox eloid DIY-CNC Router Table Machines 4 12-06-2009 08:54 AM
first post can the rack an pinion be used to drive x axis rather than screw on lathe ken ben Mechanical Calculations/Engineering Design 3 10-17-2009 09:57 PM
Rack and Pinion for x, y axis question ??? zeoncomp CNC Plasma and Waterjet Machines 2 09-22-2007 09:19 AM
Rack and Pinion Hillman Linear and Rotary Motion 1 08-09-2005 04:14 PM
calculatiing pinion size for rack and pinion setup Apples DIY-CNC Router Table Machines 3 05-18-2004 09:36 PM
