Results 1 to 4 of 4
Thread: Design critic needed for an 80/20 linear system
    May 2008
    I want to start by saying - Wahoo - my first post!
    Now that that is out of the way I am interested in building my first CNC machine and I want to see what people think of my linear bearing design. Its based on a fiarly common practice of mounting bearings to an angle but a little more refined. I will use ground and pollished 1/2" steel mounted on 80/20 1530 extrusion through the bottom with 1/4-20 bolts (bolts not shown). As for my angle I will use 1/2" thick aluminum angle milled to shape and shoulder bolts retaining the bearings. The shoulders are recessed slightly into the angle to put the shoulder in shear under load. Anyway - I would have a set on top and bottom to capture the profile of the 8020/steel rail. What kind of accuracy do you think I can acheive with this type of system?
    Attached Thumbnails Attached Thumbnails Design critic needed for an 80/20 linear system-rail_concept_1.jpg
    Apr 2007
    I would think that the portion of the 8020 that the rod sits on will flex enough to give you alignment problems. I would think that it would work better if you mounted the rod to a flat bar that sat on the 8020 instead. Or you could use something like the 3075 material that has a solid edge.
    Gary
    Oct 2006
    I have built X-Y tables out of 80/20 and used Thompson Bearing products, they have several rod configurations to choose from. I use thier linear bearings on the tables. I buy my parts from a co. called Linear Ind. in Monrovia Ca. they carry anything you may need for linear motion.
    Registered solodex2151's Avatar
    Nov 2006
    I would try using Ahren's linear bearing products. Specifically designed for 80/20 and not too expensive. However, if you want to roll your own, the main problem I see is the attachment of the angle and rail might be difficult. I agree with Gary on the 80/20 flexing a bit to much for your liking, but only on an unsupported span greater than 3'. Use their deflection calculator to see if your design can tolerate it.
  1. new linear drive system
    By rceebuilder in forum Open Source CNC Machine Designs
    Last Post: 08-21-2006, 01:22 PM
  2. design of linear motion system
    By pluto in forum Linear and Rotary Motion
    Last Post: 10-17-2005, 01:49 PM
