Results 1 to 5 of 5
Thread: Precision T-Nuts?
    Jan 2010
    Precision T-Nuts?
    I really like 8020 extrusions for ease of use, cutting (carbide blade on a tablesaw works great), versatility, etc. Also, they are very straight and with close tolerances. But the T-Nuts fit loosely in the slots. With such good tolerances inside and out, wouldn't it be possible to create/sell close-tolerance T-Nuts that fit more tightly and accurately in the slots?
    If they exist, I've never seen them advertised.
    Just wondering.
    Gary
    Registered RedskinsJBS's Avatar
    Oct 2010
    I don't really see a need for precide t-nuts. You can simply wiggle the aluminum around until you get it where you want it. Then simply tighten the screws and lock it in place.
    "The bitterness of poor quality remains long after the sweetness of low price is forgotten"
    Registered TNUTZ's Avatar
    Feb 2010
    Drop-In with springball
    We have a great product with many thread sizes to solve your problem. Check us out at Your #1 shop for Aluminum T-Slotted Extrusion hardware. Depending on your extrusion size (10 series or 15 series), you would need a DB-015. They are Drop-in T-nuts with a small spring-ball underneath. The top of the T-Nut has a small, raised edge. When the T-Nut is inserted into the T-Slot, the spring ball holds it in position. The raised edge ensures that the nut is properly positioned, and the threaded hole is perfected centered in the t-slot.
    Hope this helps.
    Jan 2010
    Quote Originally Posted by TNUTZ View Post
    Hope this helps.
    TNutz,
    Thanks, yes this does help. But . . . ummmm . . I went to your website to order and it insists that the price is zero and the shipping is $15. And I wasn't trying to order the free sample.
    Gary
    Feb 2010
    Problem fixed!
    Hello Gary! Sorry about that; we recently did some updates and still have some small issues to fix. Everything should be fixed now and thank you so much for bringing this to my attention!
    1. leadscrew nuts and half nuts
      By jayhawkman in forum EBAY ADS
      Last Post: 11-07-2009, 02:00 AM
    2. Precision Nuts for stock leadscrew
      By kdoney in forum Benchtop Machines
      Last Post: 02-14-2006, 05:12 PM
    3. Nuts are driving me nuts!
      By Cold Fusion in forum CNCzone Club House
      Last Post: 06-13-2004, 12:40 AM
    4. Replies: 6
      Last Post: 03-05-2004, 11:11 PM
    5. Nuts; I'm thinking about my nuts
      By Stevie in forum General Metal Working Machines
      Last Post: 02-28-2004, 06:55 PM
