Results 1 to 9 of 9
Thread: Looking for t slot table
    Jul 2003
    california
    i am looking for t slot table for my gantry. i can not find table material. where do i look for it?
    Todd
    May 2004
    I've never seen any for sale myself.
    I think your best bet is to scavenge some off an old mill. Or, you could always assemble your own (i.e. aluminum extrusions bolted together like Techno-isel does).
    Carlo
    Feb 2005
    One option is assembling, or joining sections of 80/20 extrusion.
    The only T slot table I know of, in metal, is from Techno Isel. They have a nice extrusion available in 16.5 inch widths, but it aint cheap. !00.00 a foot.
    For small stuff, you can buy the milling tables from a tool store, or replacement Mini Mill tables from LittleMachineShop.com. Or of course try to snag a Bridgeport table off eBay.
    For your gantry router, the stuff from 80/20 or Techno Isel would work nice.
    Halfnutz
    Feb 2005
    Todd, what size are you looking for ?
    Jul 2003
    california
    i had no particual size in mind. i guess it is a matter of expense and how much of my gantry i am willing to cover. my table area is 49inches by 60inches. i thoght it would be nice to have the whole thing covered but it is looking expensive. thoughts?
    Todd
    Jan 2005
    Missouri
    You could try using a table with grooves routed into it to accept an aluminum t-track. http://rockler.com Type in aluminum t track into there search . There are all kinds of knobs and clamps that can be used.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Registered Nono's Avatar
    Mar 2004
    Vancouver, USA
    The t slot track from rockler is good for making jigs as well.. I have used it several times and tend to by extra just for future use. Have you considered just milling a t slot in your table? I have seen people surface there table to make it true after it is installed. After you do that mill out the bulk of the slot and then change cutters to a 10-315-032 ( www.travers.com ) Page 249 and you have your unknown size tabel....
    Sep 2005
    UK
    Hi, This is an area i am looking to work on next, my thoughts start around a sizable plate of aluminium ( in the UK ) which is level and flat, rout your required groves only a couple of mm deep big enough to take an ali extrusion for slot width, This ensures slots are srtight with machine axis, next fix top of slot (TEE) to ali extrusion, then run machine over table to ensure flatness and slot width.
    Hey presto machine table done.............sounds too easy to me
    CNCezee
    cr2
    cr2 is offline
    Jan 2011
    1. Trade offs between Moving Gantry and Moving Table
      By gregmary in forum DIY CNC Router Table Machines
      Last Post: 04-22-2011, 02:48 PM
    2. 5th even 6th axis? how does it work
      By ToMMY2ooo in forum General Metal Working Machines
      Last Post: 10-04-2004, 04:58 PM
    3. Aligning cross table is driving me crazy. Ideas?
      By pigifly in forum General Metal Working Machines
      Last Post: 07-07-2004, 03:45 AM
    4. Cost / Price of a DIY CNC table.
      By Havic in forum DIY CNC Router Table Machines
      Last Post: 03-01-2004, 03:08 PM
    5. Sanity check- 6'x10' table
      By Zephrant in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 05-13-2003, 12:09 PM
