I would try just machining in one direction (x)...checking it....reversing direction and checking it again...if there is backlash it will show up there. Do the same for the Y. Of course you could just lock the table, using a dial indicator to measure table movement and manually attempt to move the table in each direction....that will also give you the backlash number, plus then you'll know where the problem is. |
