10bulls. I thought maybe something was wrong with PID settings, so I spent the better part of the day checking and changing parameters. Found nothing wrong there, and no change on test cuts. I've attached another cut that also has me baffled. All dimensions within red measure exact to drawing dimesions, but the area in black is +.080" out when cut. These holes measure 5.175" outside, and if you recall from my first post, I did a 6 hole test X Y in 1" increments that I got to measure exact. It appears when circles or a radius is apart of linear moves the program or hardware has issues. I did as you suggested and changed CV to exact stop and no change occured. Have you ever heard of encorders causing this type of issue. One would think all coordinates would be varying. I can cut 100 pieces and all measure the same. I have to get operating ASAP as production is needed. Thanks for hangin in there. |
