HI Rico,
to get times for your jobs in alphacam, goto file and click setup sheet, this will out put a drawing and list of all the operations on the current job, along with a time for each operation.
this option is only selectable when you have a job open which has toolpaths or drillings on it.
as long as your tool feeds are set correctly in the tooling files then the times are usually quite acurately.
alternataivly there is a line you can input into your post, when you out put the job the time to run the panel will appear at the top of the program.
john |
