I'm guessing:
Newton (unit) - Wikipedia, the free encyclopedia
im trying to find out what " - Load max. - 5000 N" means in this technical data sheet...
TECHN. DATA / ITEMS SUPPLIED
- Aluminum cast, powder coated gray
- 2 anti rotation elements
- 2 M8x20 socket head cap screws
- 2 M8 square nuts
- Weight - .263 kg
- Load max. - 5000 N <--------------
would like to see if any one could help me with his one...thank you...want to make sure how much weight i can put on it...
I'm guessing:
Correct. 5000 N is about 1100 pounds.
CAD, CAM, Scanning, Modelling, Machining...
wow would of never guessed it...so basically its 1 ton and 100 pounds...thank you so much
No, 1 ton is 2000 lbs.
UCCNC 2017 Screenset
Because it is close to 1000 kg (a metric ton), which is 2200 pounds...
