- Counterboring for Anchor Fasteners
Banned
Hi
I'm creating a desk and in order to make it cheap I decided to counterbore the 8020 15 series myself(I also like to try new things). I have bought a counterbore JTS Machinery & Supply Co.
and made a jig to the exact parameters provided by 80/20 however I have never "machined" anything before. The jig is made of angle iron and has a 13/16" hole the exact size I need to make into the 80/20. also I only need to go down .66" and half is only the actual T slot so there is not too much material to be removed. So how should I go about this I have a Dewalt 14.4V hand drill only 3 speeds.
What speed?
Should I even bother making a guide hole or just place into the jig and start?
Also do I need to use a lubricant? Would prefer not to since then I have to clean all the pieces and wait to dry until assembly.
Thanks for any help you can give me.
Im not a machinist so take this with a grain of salt. drill speed is only part of the equation, you have the feed rate as well. Id guestimate around 800rpm with a pretty slow feed. If you jig has pretty high sides, which it probably should if your going to have straight holes, then a lubricant is probably not a bad idea and just about anything will do. I guess I would be most concerned, due to the extrusion shape and going through the T slot etc, would be the bit grabbing while handholding the drill.
- You may not post replies
- You may not edit your posts
Forum Rules
