Old 05-09-2005, 01:02 PM
James Newton's Avatar
James Newton James Newton is offline
James Newton is on a distinguished road
Yes, the linistepper is good for up to 1.5 amps per phase in microstepping mode (or up to 3 amps per phase in full or half step ) and does best for small, precise applications or where smoothness is critical.
The heat generation that H500 warns about is generally valid, but perhaps a bit over stated... Not all the power is turned into heat. Not every step results in the driver working in a linear mode. etc... But yes: It does run quite hot in microstepping modes.
