Any Suggestions I have no arc on my SA200 Lincoln Welder | | I have some of the same problems, I have a SA200 F163 Gasoline Lincoln Welder, it runs really well, I have 120 vdc at the outlet plug on the face of machine, but i can not get an arc, I have measured the the voltage at the main welding lugs and it is only 3.8 volts. Could my problem be the small PC board (idler board controller)? Does anyone know a way I can check it? |
