Old 07-10-2003, 10:47 AM
flyrc flyrc is offline
flyrc is on a distinguished road
Ok,
This may be a bit off subject but, as I mention I am using the Xylotex 3 axis board,
and Plan to use TurboCNC,
I though I would go with the Parallel setup for my limit switches,
as seen here http://www.xylotex.com/HomeSw.pdf
My understanding is that, the parallel setup basically just gives the software the signal to know that it has reached the limit.
but looking at the documentation for TurboCNC, I don’t see where to set up the pin inputs, or if I can even use the parallel setup.
any recommendations would be great.
Thanks,
