Hi, i am not sure if this is the right place to post but i have a g-code problem.
I make designs in artcam and load the g-code generated from it to mach3,problem is. The output's inverted. The only solution i did was to invert it so the result would be normal but it isn't a really good idea work inverted.
Can anyone guide me as to what i can do to solve this problem? |
