Originally Posted by Karl_T The CBK you have will run a machine right out of the box. But it won't be exactly right for your appication. If I were you, I'd pick a very simple modification to work on - say add a light to the display - read everything and try it. Be sure and keep backups so you can alllways go back. Learn one thing a day - in a month it will all make sence and seem easy.
Karl |
I have to disagree with that but only on a personal level.
I found it much easier to scrap EVERYTHING and start from a blank slate with no code in any files... (maybe it's just my way of learning)
My disclaimer would be that my machine is so far removed from any Mill CNC type application that none of the code would help me anyhow.... I did however use the old codes to check syntax examples when the book did nothing to help.
Murphy
