Old 06-27-2010, 04:49 AM
lmlamb's Avatar
lmlamb lmlamb is offline
lmlamb is on a distinguished road
Originally Posted by supertechster View Post
Larry,
I understand tat you did the x (long axis) with wire. Did you use a pulley or wrap ut around the shaft 2-3x?
How did you do the Y?
Thanks1
I am using a couple of pulleys that I picked up at Conrad Electronics here in Wiesbaden, Germany, they are 13mm with a 6mm shaft hole, hub with 2 set screws. I wrapped the wire 3 turns on the pulley, so that it won't slide when torque is applied. I also did a setup using 3/8 mxl belt for the X-axis and it works really well also. There is a little bit of stretch to the belt, so I'll be trying a different type of stainless steel cable for 50lb test to see if I can overcome the stretch.
Larry
