Left or right side cutter contour | | I'm testing the demo version of Featurcam11 2.5D and having a small problem trying to figure out how to set the toolpath to follow the left or right side of a curve. There is the groove feature but that seems to only set the toolpath to follow down the center of a curve.
If you choose inside/outside groove instead of face, you get a list of slot cutting type tool bits and not end mills?????
I have used mastercam before and it was easy to choose left, center, right computer compensation to do this.
Is there an easy way to do this?
Jim |
