It's not neccesary to remove the toner, it'll protect the copper a bit, but if you want it gone, easiest way is scotchbrite or steel wool pads, fast..
After assembly and soldering you can always spray on a layer of conformal to protect it after, or if you're cheap, semi transparent glass paint from Walmart works pretty good too, I like the blue myself..
