  #12   Ban this user!
Old 06-12-2010, 03:42 AM
F.Sharifi F.Sharifi is offline
Don Diegoo
F.Sharifi is on a distinguished road
Dear Sir
in the iTNC 530 the connection for RS232C and RG45 ( LAN ) is standard , with Cimmco Edit you can translate any Heidenhain to G code file ( go NC Function then find in this column the HEIDENHAIN/ISO Converter ) ,...
in this control you have go in manual mode press MOD key then choose the program input with ENTER key you can choose Heidenhain or ISO or Heidenhain/ISO
last things based on control software version and machine MD you can have or have note somthing , please change your data transfer with LAN cable and use TNCRemo its very easy to use and safe ,..and you dont need to tarnslate any program because control can accept and run any G code or Heidenhain if there are in memeory
let me know if you have any trouble iam expert on heidenhain
F.Sharifi
Originally Posted by yemoro View Post
Hi.
we are going to buy a cnc milling machine (kern) with a iTNC 530 control. We are currently using solidcam to writte cn programs and use cimmco software to transfer codes to our cnc leadwell 300 by serial port. We need to know if we can send directly cnc (iso) codes to iTNC530 control by this kind of serial port or we need to convert to heindenhain code. there is a better option you can tell us?
