Old 05-03-2005, 08:46 AM
CanopyFx CanopyFx is offline
CanopyFx is on a distinguished road
Drive system question
Ok I have a few more. I spent about 5 hours yesterday researching drive methods. I am building a 4 X 4 table and I can not find affordable 3/4" or 1" ballscrews. I did find several 5/8 ones that are under $100 for a 6' section. I checked several sites and they said I can spin a 5/8 screw at 800 rpm if it supported correctly on both sides. So my calculations tell me (if they are correct) that a .2 pitch screw will move 160ipm (800*.2). Is this fast enough to cut? I dont care about fast jog times, I just want to cut (plasma and a trim router)
I also researched rack and pinion. For this I think I would need to gearbox the stepper for better resolution. Now that whip is not a problem the jog speeds come up. But here is the issue here. Are there any affordable gearboxes with minimal backlash, and where are they. I found several at 20arc that were in the $400 range. Well for that price I can get 1" ball screws. If you can post sources to help me find these gearboxes I would rather go this way.
In conclusion here are my questions
1. is 160ipm fast enough for plasma cutting and thin MDF and wood routing?
2. Where are the affordable gear boxes?
On a side note:
The planning of this CNC machine is driving me nuts. I cant sleep at night because I can picture in my head it how to make this thing move with the least resistance and not come flying appart on it maiden voyage.
Joe
