Old 05-01-2005, 07:29 PM
ignatz ignatz is offline
Gold Member
ignatz is on a distinguished road
Not much time to work on the router today but I did manage to build 80% of the HobbyCNC driver (1 hour), completed the support beds and drilled all the 1.5" holes (2 hours).
The jgro plans are great. Very easy to follow so far. The only change I would suggest to anyone planning this project is that I would make the table a little larger to leave less plywood scrap. I think there is enough left over material at this point that I could have made the bed at least 2' x 4'.
This is the first time I've used the Gorilla Glue. "Wow!" is all I can say. Very strong and the expansion is great. Glad I tried it.
Here are some questions I have if anyone has answers:
1. Where is a good place to find couplings? I tried the site jgro listed but couldn't find them.
2. Should I upgrade the 1/4" threaded rod to 1/2" ACME threaded rod?
3. Can I cut the 4 3/4" grooves on the table top with the router itself?
4. Is there any reason I shouldn't make a wooden box for the electronics?
5. Would filling the gas pipe with cement to increase the rigidity be worth the effort?
6. Would a RotoZip work as the router? What are the Pros and Cons?
