Old 07-09-2003, 01:15 AM
Kookaburra's Avatar
Kookaburra Kookaburra is offline
Moderator
Kookaburra is on a distinguished road
CAD CAM
I think its called inverted time because I just turned my office upside down during the last hour trying to dig up that material I once had.
If anyone wants to put their minds to it first you created your desired shape in 2-d and broke the geometry up into a desirable facet acuracy then create your g-code toolpath. Then import your toolpath into a spread sheet and run the fill down formula. The formula was based on the workpiece circumference/ a constant RPM of the rotary/ The X travel/ The Y travel and the outcome was X movements with a foreverchanging feedrate in mm/min.
Give me a couple of days and I'll find it!
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
Greetings From Down Under
Dave Drain
Akela Australia Pty. Ltd.
