I ran into a hitch with the newest release 0.9.7, as well as the stable release about 4 months ago and just now sat down and was able to figure it out.
Symptoms: Modal Error message "Configuration System failed to initialize" and this message is thrown once for every post processor file. .cb Files no longer can be written successfully and you get two more errors when you close cambam. In the process window at the bottom it's saying that some WebClient requests are not working. It was this clue that led me to the fix.
Cause/Fix: I downgraded Microsoft .NET Framework from version 3.5 SP1 back to version 3.0 SP2 and it's happy again.
I've had .NET updates cripple other totally unrelated applications before so this is not a cambam only thing.
Hope this helps.
Love the program |
