What happens with limit switches??? | | Hi there,
I'm just in the process of converting a mill to CNC and have decided to use TurboCNC to run it. I've had a good look at TurboCNC v4.01 and how it is all setup, but need some help with limit switches.
I'm clear on how to wire it all up and then set it up in TCNC to make them work, but I have absolutely no idea what the software is going to do once the machine hits a limit. Does it just stop the axis that hit the limit? Does it stop all axes? Does it have to sorted out by going into jog mode and 'reversing' out? How does it work????
Warren |
