That is a good price for those sealed bearings. Regardless of those numbers, I would go ahead and use them. I wonder if they meant those as an axial load. I bet if you look up a standard 608 bearing that you could get an actual rating. Besides most of your loads will be of a radial nature anyway.
__________________ If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down. |
