Lol, or is it to protect the fan from your fingers? Must resist the urge!
Anyhow, I ripped that vacuum cleaner apart, and it has a nice little water pump, a 1 Gallon reservoir, and transformer. There is about 6' of narrow tubing, and the flow rate is plenty fast! Here's the guts, the reservoir just slides into the top of the plastic housing, engaging a valve (the housing is upside down at the moment), then you just switch on, and pressing the white switch on the tubing releases the water. Just what i need! |
