Originally Posted by carbidecraters Is their anyone who knows about this oiling?
trubleshtr..I can tell you arent familiar with this type of system. If any leaks are there the system will drain itself and not hold pressure. Z axis movement is constant in a cnc. |
Right!
So
1.if your system drains go look for a big puddle of oil where there should'nt be one.
2.If your system uses end of line pressure switches, and are set-up correctly you would be getting lube alarms for pressure.Oil will flow to the path of least resistance.......
Seeming as neither of these seems to be your problem,
look at anything between pump and linear rail.ie.
Metering valves not working or hyd. locked,
kinked lines.
dirt plugging the lines, from when you switched over to the new oil.
Perhaps this new oil does not have the friction capabilites your old oil did?
If it were me, I would un-do the fittings and fire the pump, does oil come out???yes...then mabey it's not enough, No well then start back tracking towards pump.
Just trying to help you out.
Further more, I do know these systems quit well. In fact If you need to buy one I'll be more than happy to sell you a re-furbished unit.
