As a side note, these machines are voltage sensitive. A rotary phase converter does not make me feel warm and fuzzy. Most transistor blowing is a result of a voltage spike or high voltage. The 208volt version had a special transformer. The 230 volt version had a transformer for that voltage. Which do you have. What does the plate on the back of the machine say? A rotary phase converter normally puts out a very high "wild" leg. What does your output to the machine measure?
George |
