Hallo
I'm working on simple dxf->g-code conversion tool - current version is available at
http://members.chello.at/grzegorz12/.../DXFKornik.rar . This rar contains all sources and executable - to start it you need QT4.1 library (available at
http://qt.nokia.com/products/library...-class-library ), program is writen in C++, configured for VisualStudio 2003). I have started this project over 4 months ago, hoping that it will take 3, max 4 weeks - and it's still waaaay from being ready.
Unfortunetly offseting algorithm is far more complex than i thought - offseting line/circle/arc primitives is easy - real problems begin at this point.
Short descrition of current version of algorithm:
Basic "unit" is class PathPrimitive that could be line, circle, arc or list of primitives. Special type of primive is "chain" -> list of connected primitives.
Offseting algorithm (childPathGenerator) goes over "chain" components and creates offseted primitives (to offset a line you need to move it's endpotins over a vector perpendicular to line, to offset arc/circle you must change it's radius - thats all), every time new offseted object is created algorithm checks if a "connector arc" is needed to connect it to previous component. Algorithm uses tangent angles at endpoints of components to calculate if connector arc is needed and how the arc should look like. At this point we have collection of small "chains" - broken at points where offseted primiteves cross each other. To connect that mess into pretty chain algorithm must cut and throw away "swarf". To do this algothim tries to find crosspoints between all primiteves in list (all to all) - every cross point is added in special list with info "good->bad", "bad->good" (decision is based on tangent angles at cross point - basically when you go "away" from orginal path it's bad2good). After all primitves are checked algorithm scans this list - everything between "bad->good" and "good->bad" is saved, other parts are cut away. At this point our "chain" is almost clean - but in sometimes it's not a chain anymore - in some cases offseted chain breaks into collection of loops (example - big circles connected with thin "pipe" when offset is bigger than "pipe" width...) and some stubborn swarf. So algorithm searches this list and collects connected primitives into chains - at the end all chains that are not closed (looped) are thrown away (if closed chain intersects all "good" parts must be looped)
And that's all, at last for today
Gregor
