Old 04-19-2005, 09:50 PM
roonster71 roonster71 is offline
roonster71 is on a distinguished road
Originally Posted by ViperTX
Yikes, check with Rutex....I'm worried about your Back EMF rating....for short durations at max rpm it will exceed the voltage rating of the FETs. I don't know if Rutex has a maximum temp. cutoff to protect the driver.
And if you're planning on running at the Terminal Voltage...you got more problems.
I'm not planning to run at full voltage people say these run fine on a geko with 80vdc
of couse you never know till you try it...... this is the first time ive ever used a servo untill now ive only run a stepper controller 24v 2a xylotex on a sherline mill that ive out grown maybe i should have got the servo first then the drive??? (chicken before the egg )
