palmerjv,
There are several things that can be done, but first you'll have to contact the front office here and provide them with your company name, product name, version number and serial number if you know it.
Each Version.ID file matches up with a particular executable and serial number, hence each one is unique and must either located or replaced. The password can be reset pretty easy if you don't know it, by simply restoring the Default.CBK file. The side effect is to doing this however, also resets all your parameters.
Tech Support
CamSoft Corp.
(951) 674-8100
support@camsoftcorp.com www.cnccontrols.com
