Originally posted by mandrew35 I'm running Mastercam V9.1 now, I'm trying to do that now with the post processor and then creating a sub from it. The Haas PST doesn't allow for me to output the long code, I've had some success with the Fanuc Post but it won't output the retract correctly and I've tried differen't ways so far. |
There should be a switch to use long code for drill cycles, otherwise, we can create a custom drill cycle to do it. (I've got custom cycles to do everything except wipe my a... never mind
Since you're using 9.1, we'll be able to either mod the post, or do a
vb script. Should be a peice of cake. The post would prolly be the best, as it is less obtrusive during processing.
'Rekd
