PCB Manufacture rom Protel99SE | | Hi NASR1,
I make pcb on my mill using Protel99SE. I export top and bottom layer cam files in Gerber format, then import into CopperCam, which exports Gcode for use in Mach3. In CopperCam you can select pads and set hole sizes etc... CopperCam is worth the purchase.
Regards, |
