Old 03-27-2010, 09:28 PM
tmfcwp tmfcwp is offline
tmfcwp is on a distinguished road
Techno offset while mid program
While running a Techno machine an offset can be created on any axis.
Pause the machine, Double click on the axis you want to change ( x,Y,Z, etc) Type in a positive number to offset the cutter to cut higher, and a negative number to cut deeper.
IE: I would type in -.1 to add that much depth to the cut.
Be carefull because the axis will do what you tell it to.
I forgot the point symbol once, and it indeed added 1 inch to the depth of the cut.
It was dramatic!!!
