Old 03-25-2010, 07:48 AM
Konstantin's Avatar
Konstantin Konstantin is offline
Konstantin is on a distinguished road
Hi. I have got some stk6713 stepper drives and have been using them with success.
Here is a post of mine with the pic of the drive. http://www.cnczone.com/forums/showpo...2&postcount=10
As I understand, the STK6712 does no uses a "current sensing" the 2 resistor that you must choose simply LIMIT the current. It is a voltage divider circuit.
Here is a configuration I have used on my drives, I am not sure if 6712 and 6713 are pin to pin compatible, but might be, so beware.
Since the STK67(12/13) are 4 phases input I have used l297 to enable the drives to use STEP/DIR signals.
Next time you test something, try using a fuse to save your electronics.
Code:
Mach 3 Dir and Step active LOW.
/***********  L297 wiring  *************/
PIN	CONN	NAME
1 	NC	SYNC
2	GND	GND
3	NC	HOME
4	PIN_9	ON STK PCB (I wire this through an inverter 74ls04)
5	NC	INH1
6	PIN_11	ON STK PCB (I wire this through an inverter 74ls04)
7	PIN_10	ON STK PCB (I wire this through an inverter 74ls04)
8	NC	INH2
9	PIN_12	ON STK PCB (I wire this through an inverter 74ls04)
10	+5V	ENABLE ***NC for now***
11	GND	CONTROL (10kOhm resistor to GND pulldown)
12	+5V	Vs
13	GND	SENS2
14	GND	SENS1
15	GND	Vref
16	NC	OSC
17	DIR	CW/CCW
18	STEP	CLOCK
19	+5	HALF/FULL (HIGH IS HALF) (10kOhm resistor to +5v pullup)
20	NC	RESET
NOTES:
GND signal must be connected to GND on the BOB board to equalize ground planes.
/************ PCB  STK 6713BMK4 PCB  *************/
J143 CONNECTOR
1	GND
2	GND
3	GND
4	Vcc1 +18 - +42V
5	Vcc1 +18 - +42V
6	Vcc1 +18 - +42V
7	GND
8	Vcc2 +5 IOH SETTING CIRCUIT
9	PIN 13 on STK6713 A  PHASE
10	PIN 15 on STK6713 A' PHASE
11	PIN 14 on STK6713 B  PHASE
12	PIN 16 on STK6713 B' PHASE
13	Vcc2 +5
STK6713BMK4 IC Pinouts
PIN --- NAME
1	 Vcc2
2	 A phase motor output
3	'A phase motor output
4	 PG motor ground
5	 SG motor ground
6	 B phase motor output
7	'B phase motor output
8	 TD1 (motor hold noise reduction use cap with pin 10)
9	 Vref
10	 TD2 (motor hold noise reduction use cap with pin 8)
11	 Vref
12	 NC
13	 A phase input
14	 B phase input
15	'A phase input
16	'B phase input
Standard motor connector J144
PIN --- NAME ---------- MOTOR LEAD COLOR
1	COMMON		BLACK
2	COMMON		WHITE
3	MOTOR A COIL	RED
4	MOTOR 'A COIL	YELLOW
5	MOTOR B COIL	BLUE
6	MOTOR 'B COIL	ORANGE
CURRENT LIMITING RESISTORS
Formula is Amps = 1.3*(R2/(R1+R2))*(5.2/0.33) (5.2 is my Vref voltage [pin 8 on J143 connector], use your logic [+5 or watever] voltage in the formula for more exact results
Amps --- R1 -- R2  value in Ohms
0.91A - 4700 - 220
0.94A - 3300 - 160
1.07A - 1800 - 100
1.09A - 3900 - 220
1.34A - 4700 - 330
1.46A - 4300 - 330
1.59A - 3900 - 330
1.70A - 3300 - 300
1.86A - 3000 - 300
1.86A - 3900 - 390
2.01A - 3300 - 360
2.03A - 3000 - 330
2.14A - 4700 - 550
2.16A - 3300 - 390
2.18A - 3600 - 430
2.19A - 3000 - 360
2.27A - 2400 - 300
2.32A - 4300 - 550
2.35A - 3000 - 390
2.36A - 3300 - 430
2.36A - 3600 - 470
2.47A - 2400 - 330
2.54A - 3600 - 510
2.55A - 3300 - 470
2.67A - 1800 - 270
2.67A - 2200 - 330
2.67A - 2400 - 360
2.74A - 3300 - 510
2.75A - 3600 - 560
2.82A - 1000 - 160
2.86A - 2400 - 390
2.88A - 2200 - 360
2.92A - 1800 - 300
2.97A - 3300 - 560
