Originally Posted by lcarrudajr The bent profile is made of 1/2 inch steel and the covers and internal support of 3/8 steel, and the table is made of 1 1/2 normalized steel plate. |
Thanks for answering... I am also working on a Big Router 10 feet x 12feet working area.. That will be able to Mill and Drill in 10" Carbon steel plates..
Can you kindly answer my following Questions:
1- What Spindle You will use? What is the Power rating (KW) and will you use VFD with it?
2- Are you using Stepper Motors or Servo Motors.. Can you share with us what is the specifications of these motors?
3- What material you will cut with this CNC ?
Best Regards
