This should do the trick.
TM
MOTION
*G0 Rapid Traverse
G1 XYZ Linear Interpolation (Feed)
G2 Circular Interpolation, CW
G3 Circular Interpolation, CCW
G4 Dwell
G12 Helical Interpolation, CW
G13 Helical Interpolation, CCW
G22 Circular Interpolation, Fillet Input CW
G23 Circular Interpolation, Fillet Input CCW
*G8 Deceleration Override OFF
G9 Deceleration Override ON
G99 Deceleration Override, Single Block
G74 Single Quadrant Circle Input ON
*G75 Multi-Quadrant Circle Input ON
PLANE SELECTION
*G17 XY, Plane Designation
G18 XZ, Plane Designation
G19 YZ, Plane Designation
TOOL RADIUS COMPENSATION
*G40 Cutter Comp. OFF/CANCEL
G41 Cutter Comp. LEFT, Left of Contour
G42 Cutter Comp. RIGHT, Right of Contour
*G44 Cutter Comp. Normal Feedrate
G45 Cutter Comp. Constant SFM
G48 Corner Rounding with Cutter Comp. OFF
*G49 Corner Rounding with Cutter Comp. ON
COORDINATE TRANSFORMATIONS
*G30 Mirror Image OFF/CANCEL
G31 Mirror Image X
G32 Mirror Image Y
*G72 Transformation OFF/CANCEL
G73 Transformation, Scaling or Rotation
MILLING CYCLES
G77 Zig-Zag
G78 Rectangular Pocket
G79 Circular Bore
G170 Outside Frame
G171 Inside Frame
G172 Pocket Frame
G173 Outside Face
G174 Inside Face
G175 Outside Circle
G176 Inside Circle
G177 Pocket Circle
G179 Slot
DRILLING CYCLES
*G80 Drill Cycle OFF/CANCEL
G81 Drill (Feed In, Rapid Out)
G82 Spot Face (Feed In, Dwell, Rapid Out)
G83 Deep Hole (Peck, Rapid Out)
G84 Tap (Feed In, Feed Out)
G85 Bore (Feed In, Feed Out)
G86 Bore (Feed In, Orient Spindle, Rapid Out)
G87 Chip Break (Peck, Rapid Out)
G89 Bore (Feed In, Dwell, Feed Out)
PROGRAMMING CODE SUMMARY FOR MILLS
G-CODE (Preparatory) & M-CODE (Miscellaneous)
G-Code PREPARATORY FUNCTION G-Code PREPARATORY FUNCTION
DIMENSIONS
G70 Input in Inches
G71 Input in Millimeters
*G90 Absolute Programming
G91 Incremental Programming
FEEDRATE
*G94 Feedrate Per Minute Mode
G95 Feedrate Per Revolution (pitch) Mode
WORKSHIFTS
*G54 Default Fixture Offset UCS
G55 Additional Fixture Offset
G56 Additional Fixture Offset
G57 Additional Fixture Offset
G58 Additional Fixture Offset
G59 Additional Fixture Offset
G92 Permanent Datum Shift
*G96 CANCEL G97
G97 Temporary Datum Shift
Z-AXIS MULTI-HOLE ROW DRILLING CYCLES
*G180 Drill Cycle OFF/CANCEL
G181 Drill (Feed In, Rapid Out)
G182 Spot Face (Feed In, Dwell, Rapid Out)
G183 Deep Hole (Peck, Rapid Out)
G184 Tap (Feed In, Feed Out)
G185 Bore (Feed In, Feed Out)
G186 Bore (Feed In, Orient Spindle, Rapid Out)
G187 Chip Break (Peck, Rapid Out)
G189 Bore (Feed In, Dwell, Feed Out)
Z-AXIS FRAME OF HOLES DRILLING CYCLES
*G190 Drill Cycle OFF/CANCEL
G191 Drill (Feed In, Rapid Out)
G192 Spot Face (Feed In, Dwell, Rapid Out)
G193 Deep Hole (Peck, Rapid Out)
G194 Tap (Feed In, Feed Out)
G195 Bore (Feed In, Feed Out)
G196 Bore (Feed In, Orient Spindle, Rapid Out)
G197 Chip Break (Peck, Rapid Out)
G199 Bore (Feed In, Dwell, Feed Out)
1104-3287
DIGITIZING CYCLES (OPTIONAL SOFTWARE)
*G200 Digitizing Cycle OFF/CANCEL
G201 Basic - Digitize Points, Lines, Arcs
G202 Mesh - Digitize XY Mesh
G203 Z-Trace - Trace Z Normal
G204 XY-Trace - Trace XY Boundary
G205 Cross-Section - (Trace)
M0 Program STOP
M1 Optional Program STOP
M2 Program STOP & RESET
(i.e., End of Program, RESET to Top of Program)
M3 Turn Spindle ON CW
M4 Turn Spindle ON CCW
M5 Turn Spindle OFF (Stop)
M6 Tool Change
M7 Coolant, Mist (also turns ON the ‘Thru the Tool Coolant’ Option, if installed)
M8 Coolant, Flood
M9 Coolant, OFF
M19 Orient Spindle (VMC Only)
M20 Program STOP, GO to Clear Point
M21 Optional Program STOP, Go to Clear Point
M22 End of Program, RESET to Top of Program but First Go to Clear Point
M25 Z-Axis Home
M26 Tool Change, Go to Clear Point
M28 Cancel Rigid Tapping Mode (i.e., Puts System in Open Loop Mode, VMC’s Only)
M29 Enable Rigid Tapping Mode (VMC’s Only)
M30 End of Program, RESET to Top of Current Numbered Program Only (Useful with BOSS 8, 9 & 10)
M36 Chip Conveyor FORWARD (Optional Part, VMC’s Only)
M37 Chip Conveyor OFF (Optional Part, VMC’s Only)
M38 Chip Conveyor REVERSE (Optional Part, VMC’s Only)
M51 Advance Index Table
NOTES:
This table was prepared using current Bridgeport Machine’s Controls available as of 4/98.
Modal & Non-Modal are defined as follows:
• Modal type code functions will remain active or effective until another code from the same group is executed.
• Non-Modal type code functions are only active in the block of programming in which it is specified.
G-Code & M-Code functions are separated into groups of Modal & Non-Modal code types. Modal code
functions are shown in a regular font. Non-Modal code functions are shown in an Italic font.
* Denotes those G-Codes which are system defaults when the machine is first powered up or reset.
CW Clockwise Direction
CCW Counter-Clockwise Direction
UCS User Coordinate System
REMEMBER:
Only ONE (1) M-Code function can be used in a Part Program Block!
M-Code functions are NOT allowed in Canned Cycle Blocks!
PROGRAMMING CODE SUMMARY FOR MILLS (CONTINUED)
M-Code MISCELLANEOUS FUNCTION
1104-3287 |
