Thanks for replying Gerry,
Originally Posted by ger21 What speed are you trying to attain? You probably want at least 30ipm, I'm guessing. |
That would be a good figure to aim for I guess, at least for rapid traverse/homing situations. I will only be cutting wood and plastics (with maybe some PCB material) and will need a 'reasonable' feed rate to prevent burning of the parts/cutters. I will be using a laminate router (20,000 RPM) with 1/4" and 1/8" collets and the largest cutter I have with a 1/4" shank is 1/2" diameter. The smallest cutters will be tiny carbide PCB type drills/mills and engraving bits. The router is being wired through a speed control too so that I can adjust spindle speed as well as feedrate.
Originally Posted by ger21 I'd try to sell the Stepperworld board on Ebay, and get either the HobbyCNC or the Xylotex. Then, try to find a 24V supply on Ebay. If you wait long enough, you should be able to get one for around $10-$20. And you really need bigger motors, preferably at least 200 oz-in. You can get these 166oz-in for $29 from http://web6.automationdirect.com/adc.../STP-MTR-23055
And if you still can't get enough speed, you need to switch to something like 1/2-10 acme. |
Yup that's what I thought I was going to have to do but I thought I would ask first before making another costly mistake :frown: . The really frustrating part is the hours I spent researching all the different options in terms of motors, drivers, power supplies etc. and I still messed up!
Originally Posted by ger21 Unfortunately, I don't see any cheaper way to go about it. You could try running 24V through the Stepperworld board, but I doubt it will give you much better performance based on what I've read. |
Neither do I. Ho hum, time to make some changes I guess.
Larry
