Old 04-08-2005, 10:23 AM
ddgman2001 ddgman2001 is offline
ddgman2001 is on a distinguished road
T-slot table vs. cast plate
I need to upgrade my table surface on my Shopbot. Right now it's an MDF vacuum fixture clamped to the main table surface which is 1/4" mild steel plate bolted to 1.5" rails.
The MDF's got to go.
I use a combination of edge clamping and vacuum clamping so am wondering about using either some cast aluminum tooling plate probably drilled and tapped on a grid or T-slot table. Vacuum jigs would get clamped onto the main fixture plate.
Minimum dimensions are 16" x 45" max dimensions are 24" x 48".
I'm mostly routing hard woods, but do a little light alu machining occasionally.
Any thoughts or suggestions?
