Originally Posted by Curmudgeon I need to learn how to do this also. Is there any additional info on how to do this, example g code, a tutorial, I could use a jump start. I think I understand the cutting margins aspect, it's the reference point and dowels I'm not sure at all how to incorporate.
Thanks in advance for the help. |
Well all I have to say is if your working with liter material your tollerances aren't go to be that good. I use a larger machine for larger jobs, but in alot of peoples cases they don't have that option. If your workng with heavier material then you will probably be alright depending on your over hang, but you still will not get as tight of tollerances as you would when having the entire part clamped down to your table.
