Old 04-07-2005, 09:04 AM
locost_cam locost_cam is offline
locost_cam is on a distinguished road
I have just uploaded V1.2.7 to http://www.sheetcam.com Although there
are a lot of bug fixes they are mainly tidying up minor loose ends.
I have also updated the two tutorials and added two plasma cutting
tutorials.
Fixed: No tick displayed when layers are enabled in the layer toolbox
Fixed: Renaming a part did not actually change the name
Fixed: Enabled/Disabled marker in parts list is now always shown
Fixed: In start point editor the leadin and leadout sizes were enabled
when 'use process settings' was checked
Fixed: If the last tool in the tool list was deleted, the name was not
removed from the list.
Fixed: A number of hint images didn't work, especially in the pocketing
dialog
Fixed: Paths not always regenerating when you copy a part
Changed: The process list shows the processes for duplicates as well. If
you try to edit one
of the processes it automatically switches to the parent part.
Added: Tool change reduction for duplicates. If there are parts with
duplicates, each process is performed on all of the duplicates before
moving on to the next process. This can save a lot of tool changes.
Les
