Originally Posted by daisydog I want to use Madcam for woodworking but I have not figured out how to use it for engraving. Maybe this is the wrong cam for that. I have not seen any engraving tools.
Thanks,
Ddog |
DDog, as sven and Dan have posed the question, could you elaborate on what you mean by engraving? I happen to be a wood worker who uses Madcam exclusively. If you are talking about scribing letters, lines, or other such uses, then yes Madcam can do it all. If however, you are talking about doing photo replication in wood, then Madcam will not work for that unless you create a surface in Rhino that gives you the z depth changes that will produce the image in wood. With that said, you can create those types of surfaces in Rhino, but I am not good enough with it yet to be able to try it for an actual engraving/routing.
Can you post photo of the type engraving you are talking about?
Mike
