Old 03-05-2010, 03:34 AM
CNCZILLA's Avatar
CNCZILLA CNCZILLA is offline
CNCZILLA is on a distinguished road
If the machine is telling you it needs reference established for the Y then establish it. This is done with parameter 1815. This needs to be set for the corresponding axis in order to tell the machine where reference is. Once this is set then you should be able to move the axis. After you set this ref bit to a 1 then you need cycle the power to take. Try this and see if it helps.
