  #12   Ban this user!
Old 07-05-2003, 11:34 AM
kong kong is offline
kong is on a distinguished road
Hooray, the motors turned up today, and they are huge! Well, by stepper standards anyways. So I'm itching to test them, but don't want to blow myself up. On the back I have six connectors. A1 A2, C1 C2, F1 F2. From page 3 of the manual, I see that A1 is armature + and A2 is -. As the voltage is 220dc max, i assume I could use a 12v or 24v supply, as that is all I have available at the moment. Now C1 and C2 are the two field coils positive, and F1 and F2 are negatives. It says to use only F1 or F2, I guess switching these will reverse direction? Also, it says max current 80ma, so I guess again that the voltage will be 220v max, so I should use the same voltage as the armature. The stupid question is how do I limit it to 80ma, or do I need to limit it at all, as I'm guessing it may only draw 80ma max from whatever supply I use. As you can tell, I know nothing about electronics, and even less about servos! Ok, looked up the current limiting and I obviously need a resistor to do it.
I can supply a photo of the connectors if needed. Thanks!
