Originally Posted by camsoft Murphy,
On the SETUP screen under Design Operator Screen you will see a button titled Jogging Window simply un-check the box labeled VISIBLE. |
That seems to have disabled the JOG function...
When I click the finger icon, the jog no longer works.
Perhaps I wasnt specific.
I want to keep the playstation graphic jog buttons. (I like the way you made them light up when pressed) But I want to get rid of the gray box that surrounds that playstation graphic. (I need to keep the jog function)
You mentioned the visible property.. Can I set that with code? At least this way, if its not possible to do it the way I want, I can make it invisible.
Thanks!
