Old 04-05-2005, 02:01 AM
Torsten's Avatar
Torsten Torsten is offline
Torsten is on a distinguished road
Originally Posted by rcazwillis
I purchased the HF Mill/Drill machine and want to CNC it. I have been looking at the Xylotex driver with some motors from AutomationDirect. The motors are 276 oz-in rated at 2.8a. These were both recommended by folks here on the board.
I am concerned that the motors and drivers will not be large enough for the mill. Any feedback or thoughts would be appreciated.
I agree at a 1:5 maybe 1:6 ratio they would probably work check the
torque curve on the motor to find the RPM at wich they still produce
adequate power from that you can calculate what kind of speeds
you could get with those ratios.
I would guess about 15-20 IPM is about what you could expect.
Maybe O.K. for a patient hobby guy but definatly out of question
for any kind of commercial use.
Going with more powerful motors will require different and more
expensive drivers also figure to double your estimates.
Good Luck
