Mech, the way I understood it you could do exactly what you are doing. I think and or I am hoping that I can even do that with only 1 limit switch on each axis. If I remember right you tell it which way to travel to find the limit switch and then it backs off a preset amount that you specified and as you say 1 axis at a time til all are homed. 1 axis at a time is better than losing position and having to start over at square one!.
Originally Posted by mecheng10 I have my 3-axis cnc mill set up to run the shared limit/home switches on all three axes from a single pin and it works fine on my machine so I know it can be done. When you set all the limits and home signals to the same pin Mach 3 is smart enough to know how to interpret the signal based on the context of the machine at a particular time. The only drawback I have found using this method is that the axes have to be homed sequentially (one at a time) which takes a little longer.
-Brian |
